Stock Hand Guard Mounting
I am having a hell of a time getting the stock (or sold as) hand guards to fit. I can get the right side on but the lever is now pointing up too much and I can't get it to be level..
The left side doesn't work at all. With it on there isn't enough room to get it on there and not bind up on the clutch lever and that is dangerous. Has anyone had this issue? And if so why are they being sold as such? I don't like modifying things just to fit because it voids the warranty and I really shouldn't have to if they are sold like they fit. Frustrating. ![]()
2016 CSC RX3 Silver |
Can you post some pix? This is discouraging news indeed.
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
I didn't buy the CSC hand guards, but I'm sure someone who did will soon reply. In the meanwhile, please do post some photographs of your installation. I am interested to see the problem, and I'm sure others are interested as well.
Hummm, I recall reading that the '16 models had bar end weights installed by the factory. In order to keep the total width the same they (the factory) decided to make the bars themselves shorter. That means we now have clearance issues with the hand guards. CSC immediately saw the problem and is going to send out new bars that are the 'old' size so we won't have the clearance issue. I saw where the replacement bars just came in so I would expect to get a package any day now.
Peter Y. |
Ryan told me they are expecting the new bars shortly. I emailed him last week about the time frame.
2016 CSC RX3 Ginger Edition Check out my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/ |
Here are the Pictures.
First shows the tight clearance. Can't move the clutch lever over enough without it going onto the curve of the riser portion. Also you cant get the guard mount very tight to the light switch as the wires are smashed between the two. ![]() Next is the lever hitting the guard mount, there is a little cam that engages the clutch switch underneath that hits. ![]() This pictures shows the lever just clearing the mount in the open position. The little switch cam on the lever not hitting. ![]() Hope these help but a little notice about the bar issue would have been nice from CSC before they were sold as the package deal, now I'm stuck with unusable guards, wife is not happy... I'll contact CSC about a possible return, I hope as I already tossed all the packaging.
you do not need to send back the guards Ryan will send you the right bars all you have to do is tell csc
Peace and Zong Life
" Also you cant get the guard mount very tight to the light switch as the wires are smashed between the two."
On mine I took the light switch apart and cut the place where the wires come out and moved that slot down father to get the wires to come out closer to bottom of switch. This gave added clearance to get the CSC hand guard mount right up against the switch with wires coming out just below CSC HG mount. Mine is last years 2015 model. rj
Live Zong, and Prosper |
#9 | |
Anyone have the measurements of the 2015 bar? Width would be good. I might just get a set of nicer bars if I have to replace them anyway.
#11 | |
Thanks for the tip, RJ!
#13 | |
Wow, you have a bit more room on your bars than I do. Just moving my lever over slightly and I was into the riser portion of the bar. I would guess they cut a good 3 to 4 inches off to fit the weights. ![]()
#14 |
#15 |
Called Ryan, new bars are in the works. Looks like we didn't get on the email list for the info.
