Old 09-18-2015, 10:57 AM   #1
NoVa Rider   NoVa Rider is offline
Seeps Weeps and Leaks
Minor story that would be better if illustrated with photos -- sorry I am photo challenged.
Had an issue with oil weeping from top of cylinder head. After a ride, oil would be slowly coming down around the cylinder head bolt just forward of the spark plug. Not enough to be too messy but something needed to be done. I determined it was coming from the top of the engine, not from the head bolt itself.
I removed the tank, and focused on two 10mm (head size) bolts on the top right side of the cylinder head, each with copper washers. I believe these bolts may secure the cam bearing, so I decided to deal with each one individually, and not unscrew both at the same time. I backed the bolts out about a 1/4 inch, and using the tip of an exacto knife, I applied some "blue goo" (Permatex Hylomar gasket dressing) on both sides of the copper washers. Then retightened the bolts. While I was at it, I also removed the exhaust valve adjustment cover and applied a bit of blue goo around the edge. I am fairly confident, however, the leak was not from the valve cover.
Problem seems to have been solved.
Old 09-18-2015, 03:40 PM   #2
Thanks for informing us. I'm guessing the two bolts were not tightened properly at the factory.
Old 09-18-2015, 04:30 PM   #3
detours   detours is offline
detours's Avatar
I love all the updates on individual issues. I don't have this one, but I learn so much about what could go wrong and how to fix or adjust them.
Red 5 standing by!
2014 Ural Patrol
Old 09-18-2015, 04:57 PM   #4
Riceburner   Riceburner is offline
Riceburner's Avatar
Location: Tigbauan, Iloilo City, Panay Island, Philippines
Thanks NoVa Rider for the info.
Riceburner
Robin / Face Hunter I
Medical Mission Matters
www.medicalmissionmatters.org
