Old 12-15-2015, 06:34 PM   #1
jbfla   jbfla is offline
Lowering
The narrow seat didn't bring me any closer to the ground.
The advertised seat height of the RX3 is 31.3 inches. The seat on mine measures 32". The narrow seat is no better.
So it's time to get back on the ground again...
Thanks to rjmorel for his lowering link post and the CSC tutorial.
http://www.chinariders.net/showthread.php?t=15514
I purchased the link with the bearings already installed, a great help.
They must use a impact wrench when tightening the bolts on the link.
Loosening the nuts was one of the hardest parts.
The other hard part was trying to get back up off the ground...
I still can't get my feet completely flat on the ground. I have to slightly lean to one side or the other.
Next is to raise the forks up a bit.
Also, I think the preload is not set right. Only 3/4" rider sag with all my gear on. But that will have to wait until I do the valve check...when the bike is already apart.
jb
2014 XT 250........
Old 12-15-2015, 06:53 PM   #2
rojo_grande   rojo_grande is offline
rojo_grande's Avatar
Yep. Marzhere was looking at the narrower seat as well. Even though narrower, its not any shorter than the stock seat.
We opted to shave the stock seat down a little and make it a little narrower. Although there's not much padding to shave.
We also got the lowering link installed which helped quite a bit. Got Marzhere off her toes and down on the balls of her feet.
We did not move the forks up in the triple trees as yet.
Rojo
'15 RX3 (Rojo's)
'15 RX3 (marzhere's)
'16 TT250
Old 12-15-2015, 09:03 PM   #3
I have installed lowering links on both my Honda XR650L, and Honda CRF250X. Moving the forks up in the triple tree helps a lot to lower the saddle height.
Old 12-15-2015, 09:42 PM   #4
pepelepua   pepelepua is offline
pepelepua's Avatar
Sorry I couldn't found how much can you lower the seat with the new link, can you tell us?
Thanks!
Pablo.
Today Riding a Corven Triax 250 Touring (Zongshen RX3)
Old 12-15-2015, 10:44 PM   #5
The specs from the CSC website say it's a 1" lowering link. I didn't do before and after measurements but that seems accurate.
The stock bars without a riser only allows for ~3/8" adjustment to slide the forks up. At least for now Marzhere is ok with the set up, but good to know it will make a difference if need be.
Thanks
Rojo
'15 RX3 (Rojo's)
'16 TT250
Old 12-15-2015, 11:02 PM   #6
detours   detours is offline
detours's Avatar
Yeah, the narrow seat isn't any lower than stock, but it's a lot more comfortable.
Red 5 standing by!
2014 Ural Patrol
Old 12-16-2015, 12:52 AM   #7
Does anyone have comparison pics of the original link and the lowering link?
Old 12-16-2015, 01:19 AM   #8
Yes, here is an image from the thread which is linked in the first post.
Old 12-16-2015, 01:30 AM   #9
Thanks
Rojo
Tiger12XC raised the forks 1/2-inch, and documented his work in the following thread.
http://www.chinariders.net/showthread.php?t=15396
You will definitely notice a lowering of the saddle height if you raise the forks the same amount.
Old 12-16-2015, 10:44 AM   #10
Those are good pics of the stock vs. lowering links. I forgot about RJ's thread.
